My truck is starting but wont crank up 2000 Bravada Oldsmobile
2000 OLDSMOBILE BRAVADA
182,000 MILES • AWD • AUTOMATIC
SHAKU
Ok on Thursday my truck was working just fine and Friday I went to go crank up the car up and it wouldn't start everything in the car is fine and when the mechanic bang the fuel pump it cut on for 30 seconds and cut off so I got a fuel pump pressure sensor and a fuel pump and it still won't start I've tried to jump it and it still won't start starter fluid and it still won't start check the wiring also what could possibly be wrong with my 2000 Bravada Oldsmobile I spent over $400 trying to get it fixed and it still isn't fixed been down for a week
May 8, 2015 at 6:42 AM
CADIEMAN
  • 3,544 POSTS
does it spark at every spark plug wire? ck. with a test light.
May 8, 2015 at 7:04 AM
SHAKU
Now I just got spark plug, hoses, another sensor and he clean the line and still no spark ugh that's more money I don't have now another mechanic just came and say it the Mongolian in the disputer could this be the problem I'm running out of funds and can't figure this out
May 10, 2015 at 3:24 AM
CADIEMAN
  • 3,544 POSTS
u will need to ck.for power at the posiftive szidxe of
May 10, 2015 at 11:32 AM
CADIEMAN
  • 3,544 POSTS
make sure u are geting power to the positive side of the coil.
May 12, 2015 at 10:10 AM
