it shakes like vibrating wants to shut off?
152,000 MILES • 3.5L • V6 • 4WD
CEECEE1100
When I leave home and I stop it shakes like vibrating wants to cut off, but I keep my feet on the gas, and it goes but when I get where I'm going it cuts off. what is that?
Jul 13, 2022 at 10:42 AM
  • 110,248 POSTS
This could be a few different things. Most commonly, it is an engine vacuum leak, that can cause a rough idle or stalling. Also, a plugged air filter can be the issue. Have you checked it to make sure it isn't clogged?
Here is a link that explains how to test for vacuum leaks. If the air filter is good, this is where I would start.
Let me know. Also, let me know if the check engine light is staying on when the engine is running. If it is, the computer should be scanned to determine what trouble codes are stored. If you don't have a scanner, most don't, often times a parts store will do it free of charge. Let me know if you are able to retrieve codes if the light stays on.
Jul 13, 2022 at 4:07 PM
