My transmission stays on third gear
100,000 MILES • 6.0L • V8 • 2WD • AUTOMATIC
RICKY ESTEVIS
My tuck (Classic hd) works perfect when I am driving without my AC on. As soon as I turn the AC it slips and stays on third gear. And it never fails to happen. Sometimes if I turn my truck off with the AC on my truck will not turn on unless I lift my junction fuse box. I recently replaced the blower resistor and it worked for a couple of days but now it does not even blow air.
Oct 28, 2018 at 12:59 PM
  • 55,797 POSTS
Did this problem start when you replace the resistor? We should start by running the codes. It sounds like the BCM is bad.
Cheers, Ken
Oct 30, 2018 at 5:58 AM
