My clutch
99,000 MILES • 1.2L • FWD • MANUAL
COURTNEY JOHNSEY
I was driving my car and all of a sudden I tried to change gear and my clutch was stuck to the floor. I pulled over pulled the clutch leaver back up and now my clutch has no compression and I cannot select a gear.
May 12, 2017 at 7:52 AM
HMAC300
  • 48,601 POSTS
what has happened is you have pushed the throw-out bearing through the pressure plate. time for a new clutch.
May 12, 2017 at 8:46 AM
STEVE W.
  • 15,419 POSTS
Either pushed the bearing out or the slave cylinder has failed. Either way it has to come apart to be repaired.
May 15, 2017 at 5:11 AM
