Car stalls and putts when accelerating and braking
136,660 MILES • 3 CYL • 4WD
DOMWILSON155
My car has no dash lights on at all. When i start to drive and pick up speeds it stalls like out wants to shut off. It does it at least four times and then it is fine and starts over again including jerking. The car rides smooth but the stalling and jerking has to stop. please help.
Jan 18, 2018 at 12:18 PM
STEVE W.
  • 15,420 POSTS
I would take it to a dealer or good shop and have them run a scan to see if there are powertrain codes stored. Not all codes will turn on the light, some will be there but unless scanned they are not discovered. If there are no codes stored or pending then the job becomes more difficult.
Jan 18, 2018 at 3:32 PM
DOMWILSON155
The car was already scanned and nothing was done to fix it i need to know what makes the car hesitant and stalls when drivig
Jan 23, 2018 at 7:08 AM
STEVE W.
  • 15,420 POSTS
First question - What engine does it actually have and gas or diesel. You have 3 cyl but they used a 2.0 and 2.4 gas and a 2.0 diesel in EU and Aus. Also which transmission
What codes were found when it was scanned if any? With that description I would expect a code or two. If there are no codes then you will need to attach a scan tool on it and watch the live data to see what is dropping out or changing. There are multiple parts that could cause the engine to act this way, anything from a bad crankshaft sensor, failing O2 sensor, loose battery cable, bad engine ground or even transmission problems if it has the CVT unit as just a few examples. However without reading the data you could replace every part and still miss the actual cause. In the auto world we call that "firing the parts cannon" and it is very expensive. We try not to do that if at all possible.
Here are a few questions that might help narrow it down.
Did this just start doing this?
Were ANY changes made before it started (new parts, plugs, sensors, different gas station)?
Does it seem to happen more when the engine is cold or does it need to warm up?
Does it seem to be better or worse if it rains/snows?
Does outside temperature effect it?
You say it does it while accelerating, if it starts acting up and you let off the fuel what happens?
Does it seem to be different if you slowly accelerate or if you just stomp the pedal down?
Jan 23, 2018 at 10:48 AM
