My car is stalling
KVOLLMER80
  • 1991 CHRYSLER NEW YORKER
  • 3.3L
  • V6
  • FWD
  • 150,000 MILES
I was driving to work and was going along just fine then my check engine light came on then my check gauges light came on and my oil pressure plummeted. It is full of oil and all other fluids are good. I replaced the fuel pump relay but it still is happening. Mostly when I press the brake or accelerate. But will happen if just driving or just at idol. A friend told me the oil pump is going out but I need a second opinion.
Sunday, May 29th, 2016 AT 4:56 PM
  • 109,885 POSTS
If the gauge drops and there is no ticking or knocking from the engine, chances are there is not an oil pressure issue, but rather a bad oil pressure switch. What I would suggest is to rent a mechanical gauge. All you do is remove the electronic one on the engine and screw in the mechanical one. Start the engine and see how much pressure the gauge reads. At an idle, it should be at least 15 psi and then increase as you rev the engine. Just to make you aware, often times the switch will leak allowing pressure to be released, showing a false reading. Do that and let me know what you find. Remember, if there is no knocking or ticking from the engine, chances are what I am telling you is correct.
Sunday, May 29th, 2016 AT 6:49 PM
