Runs rough, backfiring when turned off and transmission makes a hum noise
75,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
SHAYMCDON
So I changed the spark plugs and did a drain and fill in my transmission. Now my car is running rough and it makes like a weird noise when I let off the accelerator when I try to slow down between speed of 20-25 my car makes a weird downshift noise like it hums. Plus it backfires when I turn my car off.
Jul 8, 2021 at 8:16 AM
  • 110,248 POSTS
Did you use the correct type of transmission fluid? Some of these vehicles have a CVT transmission that requires specific fluid.
Also, how was the fluid level checked?
As far as the backfire, make sure the connections on the coil packs are tight.
Let me know if this has a CVT transmission and if you are confident the correct fluid was used. Also, here is a link that discusses common transmission issues. You may find it of interest.
Jul 8, 2021 at 2:20 PM
SHAYMCDONA
I had the Ford dealership do the work. So whatever they did it sounds like it’s messed up. But before I had this work done my car was running really rough so I thought to myself it was time to change the spark plugs and coil pack. They had the car up in the air.
Jul 8, 2021 at 9:30 PM
  • 110,248 POSTS
The spark plugs used in today's cars are iridium. They are usually good for about 100K miles. However, they too can fail.
If they had it in the air, that is how the transmission fluid level is checked. The vehicle has to be at operating temp, the transmission in park, and the engine running. Chances are that is why.
Do you presently have the vehicle? If you do, is the check engine light staying on when the vehicle is running? If it is, you really need to have the can bus scanned.
CAN stands for computer area network. Basically, all the computers/modules are tied together via a few wires. When you scan the Can-Bus, it will identify diagnostic trouble codes regardless of the module storing it. For example, if the ABS module or the transmission control module had codes, a basic scanner won't read them.
Here is a video showing it being done:
https://youtu.be/u-4syLc-ifQ
Let me know if you have questions or if there is something I can do to help. If you are able to have the computer scanned as I suggested, let me know what diagnostic trouble codes are found. Also, if you can record how the vehicle is running and upload it for me to hear, it may help me.
Jul 9, 2021 at 1:52 PM
