Engine shut off while driving and will not start
145,000 MILES • 6 CYL • 2WD • AUTOMATIC
WGARD58462
After waiting about an hour, it started up but stopped and will not start at all now. Battery is new.
Sep 27, 2021 at 12:52 PM
  • 110,248 POSTS
What you described sounds like it could be related to a faulty crankshaft position sensor. When they begin failing, heat adversely will affect them.
Do me a favor. Take a look through this link and let me know if it mirrors what you experience.
Since the vehicle won't start, we need to check for both spark to the plugs and fuel. If the crankshaft sensor is bad, there will likely be no spark.
Here is a link that explains how to test for ignition spark.
Also, see if it will start for a couple of seconds and then stall using starting fluid. If it does, then we know it is a fuel-related issue.
Try this and let me know what you find. Also, hang in there. We get it running again.
Sep 28, 2021 at 12:58 PM
