SUV shakes at low rpm's
200,000 MILES • 5.4L • V8 • 4WD • AUTOMATIC
MOSQUEDA84
It turns on fine, but once the rpm's drop below 1 rpm it starts to shake. I had just fixed it and they said it was a spark plug and it stop shaking. Now it started back up and I’m not even sure what it is. Please help
Feb 6, 2019 at 9:57 AM
BMDOUBLE
  • 1,139 POSTS
These trucks are real bad about leaking coolant from failed intake intakes (plastic ones) and intake gaskets. The coolant will travel down the edge of the intake and seap into the plug holes and contaminate the coil boots, ruin coils, and spark plugs. Your vehicle probably did have. Bad plug, but what was the root cause? If there are no signs of coolant contamination, it could be the coil. That is if it has an ignition misfire anyways. There are several other things that can cause a misfire, I’m just giving a most common scenario for what repair has already been performed.
Feb 6, 2019 at 11:41 AM
MOSQUEDA84
Would it be a good idea of just replacing the spark plugs and coil? Or should I replace the spark plug wires as well just to make sure?
Feb 6, 2019 at 1:01 PM
MOTOR MASTER
  • 279 POSTS
Hello my name is Dave.
First question I have is if you know which cylinder is misfiring? If it is the same one as before the easiest way to determine if it's a faulty coil ( there are no plug wires on a 5.4) causing the plug to foul is to switch it with another coil location and seeing if the problem follows the coil, if it begins to misfire on the new cylinder where the suspected bad coil is that tells you know if that is the most likely cause of the issue. If you need further assistance it would be of great help if you could take a picture of the tip of the spark plug from the cylinder that is misfiring. I hope this has been helpful and thank you for using 2CarPros
Feb 6, 2019 at 8:33 PM
