my 01 dodge durango is missing bad and has p0202 code
2001 DODGE DURANGO
187,000 MILES
CHASE10
it keeps coming up with p0202 code on it too the number 2 injector replaced it and wiring harness to it still missing bad i have a 2001 dodge durango i had this guy fix it back in time he said he did but i just dont know for sure i have checked all coils and injectors it still have a bad miss in it when trying to drive 40mph andit keeps coming up with p0202 code on it too the number 2 injector replaced it and wiring harness to it still missing bad up its fine but when it gets down to 20 it quits on me dont know what to do
Aug 30, 2013 at 6:56 AM
SATURNTECH9
  • 30,869 POSTS
Is there gas coming out of the tail pipe? Do you have a multi meter to do some testing?What size engine o you have?
Aug 30, 2013 at 11:57 AM
TY ANDERSON
  • 719 POSTS
The code implies the #2 injector is not operating. With what you said above you've covered all it could be except the vehicle's computer which controls the fuel injector. Assuming the injector is good and the wiring from the computer to the injector is also in good condition. The check engine light should not be flashing, is it?
Aug 30, 2013 at 12:14 PM
MADMIKE1735
  • 951 POSTS
if you have access to noid lights, you can plug one into the injector harness, and verify power and ground... chances are the pcm may have failed, and this is resulting in the injector driver for your #2 cyl to be inop.... if you verify power and ground to the injector, then the injector is bad.... its rare for a new one to be bad, but it does happen... dont over look it.
Sep 14, 2013 at 12:38 PM
