overheating
100,000 MILES • 3.4L • 6 CYL • AWD • AUTOMATIC
NEWSBOY
The car is running good but when we stop the reservoir for the antifreeze is boiling and after it cools down it needs to add antifreeze. The thermostat was replace three weeks a go and the problem stop until yesterday when it did it again. The fans work and we have done a test to check for head gasket and it was negative.
And id does not do it all the time. I can drive it all day and it will be fine and then the next day it will do it again.
Jul 25, 2017 at 11:49 AM
HARRY P
  • 2,292 POSTS
I would go ahead and replace the thermostat again. You probably got a dud, which would not be terribly surprising. It is pretty common. Start with that.
If that does not work, take a look at the cooling fan when the car is warmed up, it should be running. Let us know what you find.
Jul 25, 2017 at 12:54 PM
