Engine vibrating
238,000 MILES • 3.5L • V6 • 2WD • AUTOMATIC
FRANCOIS LEBEAU
  • 5 POSTS
Hey guys!
First, thanks for your time.
So my van has been driving very well since maybe three to four months ago. Slowly, I could start to feel vibration when i was going up a hill. The van started to check a little. And more those months passed, more my van shakes when it needs torque. But it is not consistent. Sometimes, it starts to check quite a lot, sometimes it is smooth.
It started to check on the highway when I am close to eighty mph I release the gas pedal and it stops, press again it could be still shaking or not.
It shakes pretty much when the van needs power.
I do not know when was the last time the timing belt was changed. I suspect it is from the engine timing. Should i start by changing the spark plugs and see?
Jan 23, 2017 at 8:13 AM
CARADIODOC
  • 34,415 POSTS
A timing belt problem will cause problems at every engine speed, not just when under load. Spark plugs and wires are the best suspects. Start with those, then look for the less-common things if the problem persists.
Jan 23, 2017 at 8:54 AM
FRANCOIS LEBEAU
  • 5 POSTS
Thank you! Will keep people posted with the new sparks!
Jan 23, 2017 at 8:56 AM
  • 55,770 POSTS
Please let us know what happens so it will help others
Best, Ken
Jan 26, 2017 at 5:40 PM
FRANCOIS LEBEAU
  • 5 POSTS
Yes I will! Need to do it first:) It's on my to do list!
Jan 27, 2017 at 12:38 AM
FRANCOIS LEBEAU
  • 5 POSTS
Awright, got my van fixed. It wasn't a sparkplug problem but my Front CV axle were old and loose.. Which make sense. At high speed it was vibrating, uphill vibration and if i was accelerating on a curved ramped for highway, no fun. Now I had 2 new CV axle in the front, no more vibration.
Bingo. Cost me 600$ approx
Feb 4, 2017 at 10:22 AM
  • 55,770 POSTS
Nice work! thanks for getting back to us please use 2Carpros any time we are here to help.
Best, Ken
Feb 4, 2017 at 11:01 PM
