2001 Mitsubishi Space Wagon
2001 MITSUBISHI SPACE WAGON
GLADEINV
Air Conditioning problem
2001 Mitsubishi Space Wagon Automatic
Suddenly, one of the four car a/c vents on the dashboard starts to splash light water. It stopped for a day or two and then started again. There is no smell or terrible odour noticed, and all other vents are working perfectly. The a/c also works okay, Please advise on likely cause. This has only just started in about 4 days.
Jul 8, 2010 at 1:31 PM
DOCFIXIT
  • 18,828 POSTS
Drain tube for evaporator is cloged causing water to back up and be sprayed out vents by fan
Jul 8, 2010 at 2:06 PM
GLADEINV
Thanks for your reply. Is this something I can easily fix myself, are you able to give specific instructions on locating where the problem is and how to fix it? As said it is a Mitsubishi space wagon 2001
Jul 12, 2010 at 1:41 PM
DOCFIXIT
  • 18,828 POSTS
Drain tube goes from bottom of HVAC box pass side through bulkhead.
Jul 12, 2010 at 2:32 PM
