how do u check if good fuel pump on 91 3000gt
Jul 20, 2007 at 10:31 AM
With the key on, listen for the fuel pump to prime for a few seconds. If it primes, check fuel pressure. If it does not, check for power at the pump connector; power with no operation points to a ground or the pump. If there is no power, check the fuel pump relay, then the computer feed or a voltage drop.
The owner of a 1991 Mitsubishi 3000GT asked how to tell whether the fuel pump is good. The expert said an EFI pump should be heard priming briefly with the key on. If it primes, fuel pressure should be checked because low pressure can prevent starting. If it does not prime, power at the pump connector, the ground, the pump, the fuel pump relay, the computer, and possible voltage drop should be checked in that order.
