1997 Other Mitsubishi Models idling
1997 MITSUBISHI
12,500 MILES • V8 • FWD • MANUAL
DAYVID19
I have a 1997 Mitsubishi 3000GT. I am wondering when you turn the air conditioning on should the idle go up or should it remain the same. I recently had the alternator replaced. At a complete stop the idle is at 1000 rpm. It does not move. Is this correct. Any information you would be able to give me would be greatly appreciated.
Thank you Gina Richmond. Virginia
Jul 12, 2008 at 5:00 AM
KHLOW2008
  • 41,814 POSTS
Hi Gina,
There is a built in rpm compensator when the AC is turned on or off so the rpm should remain stable if everything is working correctly.
However 1000 is a bit high, it should be between 750 to 850.
Jul 12, 2008 at 7:25 AM
DAYVID19
thank you would this also apply to a 1994 3000gt
gina richmond va
Jul 13, 2008 at 1:22 AM
KHLOW2008
  • 41,814 POSTS
Hi Gina,
As far as I know, Mitsubishi injection system has this all the while.
Jul 13, 2008 at 3:27 AM
