1983 Other Mitsubishi Models
1983 MITSUBISHI
102,000 MILES • 4 CYL • 2WD • MANUAL
SPOONDOG
'83 Mitsubishi Starion, engine stalled while driving, then started missing/backfiring, running very rough. Started up a few days later, the same but no smoke (but still not driveable, revs up and down). Then next time I started it up lots of smoke, now won't start at all...
Engine is 4G63B intercooled 2L turbo (EFI). Bought off a dodgy little bearded car dealer, then the day I drove it home, it did this. He did mention that the balance shaft was out of sync, which caused some vibration... but I'm guessing that's not the problem now. Cambelt was done very recently.
Nothing seems visually obvious under the bonnet, but I didn't look at it for long. I suspect something to do with the turbo/EFI, or worse.
Jul 8, 2008 at 12:59 PM
KHLOW2008
  • 41,814 POSTS
Hi Spoondog,
Get the ECM error code if any.
At the fuse box you would see a white 12 terminal (only a few will have terminal points) connector, that is the diagnostic connector. Attach a voltmeter or LED bulb to terminal 1 and 12 and turn on ignition switch.
Count the number of blinks and post reply. Will see what needs to be done.
If continuous blinking, then no codes have been stored. Hope you have not removed the battery and it is not flat, if not the codes would have disappeared.
Jul 8, 2008 at 9:43 PM
