Yes you can change the belts yourself. First you must loosen the pullies that has the adjustment bolt with it once the pullies are loose then adjust the adjustmrnt bolt to loosen it. Then replace belts. Then tighten the belt up then then tighten the pullies back up.
SPONSORED LINKS
Wednesday, November 25th, 2009 AT 6:09 PM
