1999 Mitsubishi Montero steering wheel
100,000 MILES • 6 CYL • 4WD • AUTOMATIC
MENGHUY
hi sir, i have a 1999 mit. montero sport. the other day i changed the front sway bar end bushings and sway bar bushings in the rear.
now that i try to back up the vehicle from my drive way. as i turn the steering wheel to the right side. the steering wheels kind of tight to steer for a moment then it went away. i repeated it again it does the samething. i appreciated if you can tell me of what wrong with it.
Nov 12, 2009 at 1:37 PM
  • 31,937 POSTS
Hi there,
The work you have done should not affect the steering, i would first check the fluid level, and with both wheels in the air turn the steering by hand (engine off)at the wheels and see if there is a tight spot.
Mark (mhpautos)
Nov 12, 2009 at 6:08 PM
