Hi Luc,
If the noise is from the engine lower part and increases in level, you need to replace the con-rod and bearings and grind the crankshaft. It is driveable now, but will jam up anytime. I would not drive it to prevent more damage.
SPONSORED LINKS
Saturday, July 5th, 2008 AT 11:05 AM
