2000 Mitsubishi Mirage OEM Tachometer
2000 MITSUBISHI MIRAGE
116,000 MILES • 4 CYL • FWD • MANUAL
RENOAZ
What should I look for causing OEM tach to quit working?
Jul 7, 2010 at 11:54 PM
BABAESABALETE
it could simply be dusty old. try removing the tachometer by disassembling it from the dashboard... clean the fuses, the wires, and while your at it probably clean the other devices as well lol. it is also possible that some fuses are already dead... the thing with the 2000 mirage is that some of the fuses and wires are sort of parallel. sometimes when one device stops working, another device stops working with it.
Aug 10, 2010 at 10:36 AM
