2000 Mitsubishi Mirage Misfire
2000 MITSUBISHI MIRAGE
DANDECOUPE
Engine Performance problem
2000 Mitsubishi Mirage Two Wheel Drive Automatic 145000 miles
Hi, i have a mirage with the engine service light on. My engine starts to fail when i take off. It looses power and sounds as if it is drowning. it does it pretty much in the first or second gear. The problem detected is a misfire. I have cleaned the throttle bore and have used fuel and system additives to help. The frequency of the misfire has decreased and the service light comes back on and off after a while. What should i do before i take it to a mechanic
Jan 18, 2010 at 10:15 AM
If its misfiring and CEL on-scan the computer for codes-you have a problem within the engine management system, this is your starting point of diagnosis
Misfiring can be caused by worn or fouled spark plugs, a weak spark (weak coil, bad spark plug wire), loss of compression, vacuum leaks, anything that causes an unusually lean fuel mixture (lean misfire), an EGR valve that is stuck open, dirty fuel injectors, low fuel pressure, or even bad fuel.
Jan 18, 2010 at 10:25 AM
