1998 Mitsubishi Lancer Removal of battery caused problems
1998 MITSUBISHI LANCER
SILVERPLAYAH
Electrical problem
1998 Mitsubishi Lancer Two Wheel Drive Automatic 160000 miles
Good Day Experts,
I removed my battery terminals in the following order negative then positive and i installed the terminals in that same order. When i did that the car would shut off every time i came to a stop. I did some research and i realised that i put the terminals in the wrong order. I then proceeded to remove negative followed by positive and then install positive followed by negative. The car still wants to shut off by the way it is tumbling. Can you advise me on what to do. Thanks in advance
Sep 25, 2008 at 11:43 PM
TECHNOPRO
  • 45 POSTS
Remove your battery negative terminal for 10 minutes and tighten it back. Then start your car and leave it idling for 10 minutes as the computer needs to reset the idling speed.
Oct 23, 2008 at 9:35 PM
