Blower/fan motor works, a/c works, no heat. Possible solutions?
Thanks,
Erich
Saturday, February 23rd, 2008 AT 2:54 AM
MECHANIC
Could be stuck opened thermostat/clogged heater core/heater control valve if it has one/air mix/blend/mode door not opening or a problem with an actuator/vacuum
SPONSORED LINKS
Saturday, February 23rd, 2008 AT 3:21 AM
WILLIAM M. WILSON
MEMBER
1 POST
Had same problem, valve shut motor, it's on the passenger side heater box, about $150, dealer only item, easy to replace
