2001 Mitsubishi Galant HEATER NOT WORKING
PROPHETHAD
  • 2001 MITSUBISHI GALANT
  • 4 CYL
  • 160,000 MILES
When I put temperature control knob to hot it springs back to netral positon and no heat is coming thru vents although when I place temperature control on cold it stays. The air condition works but the heaing system does not.
Friday, November 27th, 2009 AT 4:25 PM
BUDDYCRAIGG
  • 2,262 POSTS
The temp knob operates a cable.
The cable operates a door in the duct work under the dash.
You will need to visually inspect the cable and door to see what is causing it to spring back.
Wednesday, December 2nd, 2009 AT 2:53 PM
