2001 Mitsubishi Galant Check Light on "P1400 Manifold
BALAJISUBBIAHS
  • 2001 MITSUBISHI GALANT
  • 6 CYL
  • 4WD
  • 118,000 MILES
My Engine check light is on and I got the code ""P1400 Manifold Differential Pressure Sensor Circuit Malfunction (Mitsubishi) "".
Please let me know How much it will cost to fix it. And the exact part I need to change.
Additional information: It is taking more GAS now.
Please help.
Thanks
Balaji Subbiah
Thursday, July 10th, 2008 AT 10:34 AM
KHLOW2008
  • 41,814 POSTS
Hi Balaji Subbiah,
You sure you got the code or description correct?
Data I found for the code indicates a faulty HOS sensor located on the exhaust before the catalytic converter.
Friday, July 11th, 2008 AT 12:09 PM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote="balajisubbiahs"]Engine Performance problem
2001 Mitsubishi Galant 6 cyl Four Wheel Drive Automatic 118000 miles
Hello Balaji Subbiah,
Mitsubishi's manufacture specific code does say that code P1400 is "Manifold Differential Pressure Sensor Circuit Malfunction".
However, I agree with KHLow2008 with the O2 sensor.
Friday, July 11th, 2008 AT 12:27 PM
