Engine Cooling problem
2001 Mitsubishi Galant 6 cyl Two Wheel Drive Automatic 126k miles
After a recent drive from Los Angeles to Davis, CA and back, my car has developed a serious overheating problem. I can keep the temperature down by blasting the heater or keeping the car in neutral at stop lights, but this obviously isn't terribly sustainable. The coolant, oil, and other fluid levels appear to be fine, and nothing appears to be leaking.
The car also failed a smog check this morning, despite having easily passed in the past, which may or may not be related.
The car has approximately 126,000 miles on it, but had a new engine put in about 10,000 miles ago.
Any advice or things I should check into before taking this to a mechanic? Thanks so much!
Sep 30, 2009 at 7:45 AM
