1999 Mitsubishi Galant steering sound
1999 MITSUBISHI GALANT
PONS_21
Steering problem
1999 Mitsubishi Galant 4 cyl Front Wheel Drive Automatic
when i did steerage it sound like a brake pedal holding a brake rotor.
Jan 4, 2009 at 6:21 PM
KHLOW2008
  • 41,814 POSTS
Hi pons_21,
When grinding noise is emitted while turning the steering, it is a high pressure vibration and possible causes are
1. High pressure hose loose and touching body.
2. High pressure valve partially clogged.
3. Faulty relief valve.
4. Insufficient power steering fluid.
Jan 9, 2009 at 1:21 AM
