1996 Mitsubishi Galant wont go over 30 miles
1996 MITSUBISHI GALANT
MIRNASOTO@COMCAST.NET
wont go over 30 miles its stale
Aug 20, 2010 at 8:13 PM
  • CERTIFIED EXPERT
Lack of acceleration,chugging,hesitating,bogging,misfiring etc. could be caused by one of the following below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it.
Aug 20, 2010 at 8:26 PM
