1995 Mitsubishi Galant Need Help bad
1995 MITSUBISHI GALANT
124,000 MILES • 4 CYL • FWD • AUTOMATIC
SEAN2384
My galant when I press the gas petal to give it gas putters and moves but takes forever to get to speed and i was wondering what could be the underlying issue whether it be the fuel filter the fuel pump or what please help me
Sep 1, 2010 at 8:49 AM
Lack of acceleration,chugging,hesitating,bogging,misfiring etc. could be caused by one of the following below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it.
Sep 3, 2010 at 11:08 PM
