1995 Mitsubishi Galant codes
RON00243
  • 1995 MITSUBISHI GALANT
  • 4 CYL
  • 124,000 MILES
How do I access the computer codes with out a scan tool. Which pin do I ground, on the terminals under the dash?
Friday, September 25th, 2009 AT 11:45 AM
DOCFIXIT
  • 18,828 POSTS
DLC located next to fuse box place Pos meter lead into terminal 24 and Neg in terminal 4 or 5. Key on count arm swings, Analog Meter, so if youu get two swings pause four swings you got code 24
Friday, September 25th, 2009 AT 12:11 PM
