I am trying to replace my own water pump on a 1994 Mitsubishi Galant (2.4l SOHC). I cannot get the water pump pulleys off to access the rest of the lower timing belt cover bolts. Is there a trick or tip to removing these two pulleys (small one under a larger one)? It is really frustrating as I can't bare the thought of messing with the timing belt (removing the tensioner, etc.) but I can't even get the pulleys off to see where the rest of the pump bolts are.
Mar 19, 2008 at 6:35 PM
