2002 Mitsubishi Eclipse possibily of sugar in gas tank
48,000 MILES • 4 CYL • 2WD • MANUAL
MIKE FREEMAN
I found three pixie sticks (small sugar candy straws) beside my car below the gas tank. Suspect that someone poured them into the tank. Will this small amount hurt the car. The tank is half full of gasoline. To be safe what should I do. I have not started the engine as of yet. A quick response would be great. If I need to drain the tank what is the easiest way without pulling the tank off. Thank you. Mike F.............
Jul 9, 2009 at 2:47 PM
MONTY STEPHENS
  • 79 POSTS
[Your good, top it off and go. That is not enough to harm the car.
I found three pixie sticks (small sugar candy straws) beside my car below the gas tank. Suspect that someone poured them into the tank. Will this small amount hurt the car. The tank is half full of gasoline. To be safe what should I do. I have not started the engine as of yet. A quick response would be great. If I need to drain the tank what is the easiest way without pulling the tank off. Thank you. Mike F.............[/quote]
Jul 10, 2009 at 3:18 AM
