2001 Mitsubishi Eclipse Car Horn
78,670 MILES • 4 CYL • FWD • AUTOMATIC
CRYSTAL.TOWNSEND
At first, my horn did not work, it made no sound. I checked the fuses, and after doing so, I found a burnt out fuse, I replaced it, and after doing that, my horn makes a very weak sound. could it be the relay? I was told that if it was a relay problem, then the horn wouldnt sound at all. What are your suggestions?
Apr 13, 2009 at 11:47 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Normally when the horn makes an irregular sound it is the horn itself that is faulty.
Apr 13, 2009 at 12:01 PM
GRAYSGARAGE
I would suggest replacing the horn. They cost anywhere from $10-$20 at your auto parts store.
[quote:859d943dfb="crystal.townsend"]Noises problem
2001 Mitsubishi Eclipse 4 cyl Front Wheel Drive Automatic 78670 miles
At first, my horn did not work, it made no sound. I checked the fuses, and after doing so, I found a burnt out fuse, I replaced it, and after doing that, my horn makes a very weak sound. could it be the relay? I was told that if it was a relay problem, then the horn wouldnt sound at all. What are your suggestions?[/quote:859d943dfb]
Apr 15, 2009 at 9:05 AM
