2000 Mitsubishi Eclipse timing belt broke
89,000 MILES • 6 CYL • FWD • MANUAL
ECLIPSEMLS
  • 7 POSTS
Is my 2000 Mits Eclipse GT engine damaged if my timing belt broke on the 3.0 motor? is the motor an interference motor or non?
Sep 1, 2008 at 1:44 AM
MERLIN2021
  • 17,250 POSTS
Yes unfortunatly it is an interference engine, and damage has occured....
May 20, 2020 at 3:42 AM
FEELGOOD71
  • 32 POSTS
just because it's an interference engine doesn't mean damage has already happened. I found that depending on many circumstances that it a 50/50 chance.
I would change the timing belt and see if the will run.
it's a lot cheaper than replacing the engine. and if engine damage has happened you can always put the new belt the motor you are going to install.
MERLIN2021
  • 17,250 POSTS
Pull valve covers and check for any damage...easier than doing the belt..if visible damage has occured it should have bent a few valves, or broken a few guides...if you were driving, it's probably going to have visible damage...
ECLIPSEMLS
  • 7 POSTS
[quote:1184d61428="eclipsemls@aol.com"]Engine Mechanical problem
2000 Mitsubishi Eclipse 6 cyl Front Wheel Drive Manual 89000 miles
Is my 2000 Mits Eclipse GT engine damaged if my timing belt broke on the 3.0 motor? is the motor an interference motor or non?[/quote:1184d61428]
Actually, the timing belt is ok it was the idle pulley bolt that broke, the pulley came off and the timing belt then jumped off the other pulleys. Because the timing belt came off, is the engine damaged?
MERLIN2021
  • 17,250 POSTS
Is this the serpentine belt? Or have you removed he timing belt covers?
ECLIPSEMLS
  • 7 POSTS
it is definately the timing belt. The covers were removed and that's when we discovered the p;ulley laying insidethe cover. It appears as though the bolt holding that pulley broke. Ironically, Mitubishi replaced the two pulleyss, timingbelt, and serpentine belt about 20,000 mile ago. Less than 2 years. What should I do?
MERLIN2021
  • 17,250 POSTS
I would call them and see if the work is gauranted, then tell them what happened. it could be an over or undertightened bolt that broke. Any teeth missing from the belt?
ECLIPSEMLS
  • 7 POSTS
none at all, in fact, the belt is in great condition Thanks for all your help
