HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Mitsubishi
Eclipse
Brakes
Drum
2000 Mitsubishi Eclipse
LARMCCURLEY
MEMBER
2000 MITSUBISHI ECLIPSE
How do you take the rear brake drums off?
Wednesday, July 9th, 2008 AT 4:25 PM
KHLOW2008
MECHANIC
Hi larmccurley,
The brake drums should come off after the wheels are removed.
It could be stuck and you need to use 2 pcs of M8 bolts to bolt onto the 2 threaded holes to remove them.
Some rust remover around the hub area coupled with some banging on the drums might work as well.
Thursday, March 11th, 2021 AT 1:05 PM
Please
login
or
register
to post a reply.
Related Brake Drum Content
Still Not Much Pedal I Need To Bleed My Brakes
Replaced Booster And Master Still Not Much Pedal I Need To Bleed My Brakes.
Asked by
grees20
1 ANSWER
2 IMAGES
2006
MITSUBISHI ECLIPSE
VIDEO
How to Remove a Stuck Brake Drum
Instructional repair video
GUIDE
Drum Stuck On Axle Flange
It is common for a brake drum to get stuck on the axle flange due to moisture and heat of the freshly machined metal exposed by the manufacturing process on both the axle...
1993 Mitsubishi Eclipse Hard Brakes
I Have A 93 Eclipse Gs That I Have Been Having Problems With The Brakes, When I Got The Car The Brake Pedal Was Very Stiff And You Really...
Asked by
stenlund3
1 ANSWER
1993
MITSUBISHI ECLIPSE
Brake Shoe and Drum Replacement
How to Fix a Brake Pull
