1998 Mitsubishi Eclipse hard to shift
CARFREEK1
  • 1998 MITSUBISHI ECLIPSE
  • 4 CYL
  • FWD
  • MANUAL
  • 105,000 MILES
I was down shiting to slow down I took the car out of gear fine but went to put it back into gear and couldnt. So I pulled over and set for just a minute. Got mad and forced it into first, then to second, drove in second for the 6 blocks home and now it goes in and out of realy all but second gear. I can force it in and out but im not sure what it is I have been told maby linkeg
Saturday, July 25th, 2009 AT 12:20 PM
KHLOW2008
  • 41,814 POSTS
Hi carfreek1,
You have most probably broken the gear shift cable or dislodged the linkages.
Open the hood and get someone to move the shift leve while you check the linkages at the transmission end.
Sunday, July 26th, 2009 AT 11:09 AM
