1996 Mitsubishi Eclipse turns over but there is no spark or
1996 MITSUBISHI ECLIPSE
90,000 MILES • 4 CYL • AWD • MANUAL
KELLY1969
putting in another engine, bought a new ignition coil hooked all that i can hook up that i know of, the motor turns over but there is no spark to start it. can anyone help me out letting me know what other possibilities it might be? where is the ignition control module located - if it has one? where is the engine control module located - if it has one
Oct 26, 2008 at 5:26 PM
  • CERTIFIED EXPERT
Hi kelly1969 and welcome to 2carpros
Did you check for power at the coil ? I need this answered before I can continue-we still got a long way to go figuring this out-
Oct 26, 2008 at 9:17 PM
KELLY1969
Yes there is power to the coil.
Oct 26, 2008 at 11:00 PM
  • CERTIFIED EXPERT
Scan the computer for OBD2 code/s and see if you get P0335 and P0340-this code relates to P0335 for the crankshaft position sensor and P0340 for the camshaft position sensor- Inspect and test this 2 sensors
https://www.2carpros.com/forum/automotive_pictures/12900_cps1_6.jpg
https://www.2carpros.com/forum/automotive_pictures/12900_cps2_4.jpg
https://www.2carpros.com/forum/automotive_pictures/12900_cmh1_2.jpg
Oct 27, 2008 at 2:38 AM
KELLY1969
there is no spark to the coil
Oct 28, 2008 at 8:24 PM
  • CERTIFIED EXPERT
Do you have power going to the coil black and red wire?
Oct 28, 2008 at 8:47 PM
