1996 Mitsubishi Eclipse Engine quit while driving/cranks bu
20,200 MILES • 4 CYL • 2WD • MANUAL
LISAJ1642
Hello, my son has a 96 Mits. Eclipse, he just had a new clutch installed a week ago. He said he was driving appro 60mph and all the dash lights illuminated and the engine quit, he tried to crank it over, it does crank but wont turn over. He was able to get 4 codes off of it. 11, 12, 54 & 55. I work at a bodyshop & svc center where the clutch was installed and the assistant did do something with the LT FT wheel (some welding was involved) but I just dont know! His biggest fear is the timing chain, but he said it seems to be intact, and the plugs arent bent.... do you have any advise for us?
May 18, 2008 at 10:57 PM
LISAJ1642
[quote:2b076c9fd4="Lisaj1642"]Engine Performance problem
1996 Mitsubishi Eclipse 4 cyl Two Wheel Drive Manual 202,00 miles
Hello, my son has a 96 Mits. Eclipse, he just had a new clutch installed a week ago. He said he was driving appro 60mph and all the dash lights illuminated and the engine quit, he tried to crank it over, it does crank but wont turn over. He was able to get 4 codes off of it. 11, 12, 54 & 55. I work at a bodyshop & svc center where the clutch was installed and the assistant did do something with the LT FT wheel (some welding was involved) but I just dont know! His biggest fear is the timing chain, but he said it seems to be intact, and the plugs arent bent.... do you have any advise for us?[/quote:2b076c9fd4]
May 18, 2008 at 11:02 PM
2CARPRO JACK
  • 11,533 POSTS
Need to know what engine it has in it? turbo or no turbo. Does it have spark? also check fuel pressure , get back with info
May 20, 2008 at 8:25 AM
