1996 Mitsubishi Eclipse
1996 MITSUBISHI ECLIPSE
JUDY ELZEY
Transmission problem
1996 Mitsubishi Eclipse Front Wheel Drive Manual 150,00 miles
I have a 5 speed, I was stopped at a light, and whenI went to go, my auto would not move, it stayed cranked,and I could recrank it. no noise from the clutch , just no movement, I had it towed, and when they put it up on the lift, the front tires would spin, but on the ground nothing, could it be the shear pin or limbinator end? what could the problem be? also, last month they replaced the sway bar and bushings, could there be a connection?
thank you
Jun 9, 2008 at 10:06 AM
KHLOW2008
  • 41,814 POSTS
Hi judy elzey,
Was there any rachetting noise when you tried to take off with gears engaged?
You mean on the hoist, the road wheels turn when gears were engaged?
The sway bars and bushig are not related to this.
Jun 11, 2008 at 2:15 AM
