1995 Mitsubishi Eclipse High pitched noices coming from fue
1995 MITSUBISHI ECLIPSE
90,000 MILES • 4 CYL • 2WD • AUTOMATIC
DARRENT58
I've had the fuel filter replaced and the fuel pump looked at and was told it was fine. The noise seems to only conme when there is pressure/when the car has been ran for more than 10 minutes/when already been in heat for long time then ran for 5+ minutes. If you could help me out it would be greatly appreciated.
Aug 20, 2009 at 8:52 AM
  • 31,937 POSTS
BI there.
Remove the fuel cap and start the car, listen near the filler is the noise coming from the tank? if so i feel that it will be the fuel pump.
mark (mhpautos)
Aug 20, 2009 at 4:55 PM
