1995 Mitsubishi Eclipse Engine Cutting off
135,600 MILES • 4 CYL • FWD • AUTOMATIC
ECLIPSE12
My eclipse runs perfectly, except sometimes when I'm driving it just shuts off. Its been doing it randomly and not at any specific time. After it shuts off i put it in park and to restart it and sometimes it just starts right up and sometimes the engine just keeps turning over.
Jun 30, 2009 at 7:47 AM
LEONU4
  • 15 POSTS
I would have someone hook up a scanner to your car to see if there is a current code stored. this may point you in the right direction. I assume it's a rs? nonturbo? 2.0 liter? The ideal thing to do would be to maybe carry around with you a spark tester, fuel pressure guage, noid light or a suitable tool to check injector pulse. at the time where there is a "NO START" condition would be the best time to narrow the problem down.... sometimes there is only a short window of time to trouble shoot it. & of course it could go back to starting right up & running just fine...for a while....if you don't have access to a scanner you can turn the key back & forth three times , endind in on & count the check engine light flashes. to retreive the codes if any. a scanner from an autozoner red shirter is easier, & free too.
Sep 6, 2009 at 6:08 PM
