1995 Mitsubishi Diamante TRUNK BUTTON
BLONDY1_16
Electrical problem
1995 Mitsubishi Diamante 6 cyl Automatic 204000 miles
The trunk button on my car quit working. Any ideas on how to fix it?
Sep 8, 2009 at 5:56 AM
CH112063
  • 1,320 POSTS
yes, 1. check all your fuses. 2. with a helper test for voltage at the trunk release switch when button is pushed on. use a voltage meter or a 12 volt test lamp. 3. if voltage is present replace the trunk release switch. 4. if no voltage check behind button for same voltage. 4. if voltage ok at switck, replace switch. 5. if no voltage bring to electrical repair car place or dealer for service. your welcome
Sep 17, 2009 at 8:35 AM
