MITSUBISHI ATF SPIII
125,000 MILES
2003PAJERO
hi,
recently i went to a garage to tune up my 2003 Mitsubishi pajero, the mechanic change all spark plugs and engine oil change, but he also drained my automatic transmission fluid, the problem the dealer does not sell ATF SPIII. and the car is stuck up in the garage because we could not find any compatible fluids with ATF SPIII. Please advise if there are any alternatives for ATF we can use.
Regards,
Russel
Apr 14, 2013 at 2:50 PM
you need the correct fluid for the car.
shame on the shop for doing this without having the correct fluid. press the issue as they have to secure the correct fluid so you do not have issues
Apr 14, 2013 at 6:42 PM
