Missing at idle but runs okay at 2,000 RPM's
TALMUS123
  • 2000 SATURN SL1
  • 1.9L
  • 4 CYL
  • 145 MILES
Car runs but misfires, no engine cods.
At idle come idle 2,000 rpm's car runs okay.
Sunday, May 31st, 2020 AT 9:07 AM
Can you let us know everything you have done so far to address this?
The cause of this is an imbalanced air/fuel ratio so we need to find out if it is rich or lean. Most likely this is a lean misfire because when you raise the RPM, it is dumping more fuel. So if it is lean that means we either have a vacuum leak allowing unmetered air to come in or faulty fuel system.
Let's start with this guide that talks about vacuum leaks and go from there:
Then can you monitor your fuel trims with a scan tool to see if they are in fact lean at idle? Thanks
Sunday, May 31st, 2020 AT 3:53 PM
