When driving upgrade engine misses
2007 PONTIAC TORRENT
132,000 MILES • 3.4L • V6 • 2WD • AUTOMATIC
going up an upgrade, it misses like it is not getting enough gas.
May 5, 2020 at 9:39 AM
  • 110,240 POSTS
When this is happening, does the check engine light stay on or flash? If it does, then we need to scan the computer to determine which cylinder is causing the issue and then focus on that cylinder.
Here is a quick video that shows how to scan the computer:
https://youtu.be/YV3TRZwer8k
I realize most people don't own a scanner, but most times, a parts store will do it free of charge. Have that done and let me know what code or codes are found. Also, if the check engine light isn't staying on, let me know.
Here is a link you may find of interest in the interim. It discusses how to repair a misfire.
Let me know what codes are found or if the light isn't staying on when the engine is running. I will watch for your response.
May 5, 2020 at 1:12 PM
