Miss firing
189,000 MILES • 4.2L • 6 CYL • 4WD • AUTOMATIC
SHELLY1983
1 and 4 is misfiring on my truck I have changed all coil packed and plugs when I did I saw oil on number 5 plug what does this mean?
Mar 27, 2017 at 3:11 AM
STEVE W.
  • 15,419 POSTS
Where was the oil, on the part that is inside the engine or outside?
For the misfire, you need to determine what you are missing first. Could be a bad fuel injector, low fuel pump pressure, bad connection to the coil, no spark. That is where a good scan tool with bi-directional controls is a big help. It lets you shut off each item to see which effects the engine. Now without one there is another option and that is to use a noid light to test for injector pulse on the injectors, and you can use a COP coil tester to check for spark. Run a fuel pressure test to rule that out. Most of those tools are usually rental items in parts stores, except the scan tool.
Mar 28, 2017 at 12:57 PM
SHELLY1983
The oil was in the inside on the plug where it screws in to the engine where the spark plugs sparks from. On the number 5 plug.
Mar 29, 2017 at 5:55 AM
STEVE W.
  • 15,419 POSTS
Finding oil inside isn't a good thing. It generally means worn/broken rings or that the valve stem seals are leaking, or that the PCV system it under pressure when it shouldn't be.
Lets see if we can track down the misfires first. Then at least you have a running engine to work with not something with other problems.
Mar 30, 2017 at 8:04 AM
