Misfiring and other serious issues
191,000 MILES • 3.8L • 6 CYL • 2WD • AUTOMATIC
JOSH YOUNG
When under acceleration, especially if I have to get on it a little, I can hear popping noises and occasionally the engine feels as though it is seizing up. This only lasts for a second or two after I let off of the accelerator. At that point it will go back to operating somewhat normally. If I just kind of feather the throttle and baby it, I do not seem to have as much trouble. I have scanned it and got a p1309, which is a camshaft position sensor code. I am not really sure that is the issue considering I replaced the CPS about 3,500 miles ago and have only recently developed this issue. I have also cleaned the throttle body and O2 sensors, since initially thought it might be a lack of air flow. It also pulled a p0171 and p0174. but again no difference. At this point, I am seriously considering using a match to fix the darn thing, but unfortunately, it is my daily driver.
Any help or ideas would be sincerely appreciated.
Jun 16, 2018 at 6:00 AM
  • 55,746 POSTS
This sounds like you have a flat camshaft or a broken valve spring. Here is a guide to help you can what is going on. I would remove the valve covers and check the springs and while they are off check to make sure all rockers are going up and down the proper amount.
https://www.2carpros.com/articles/engine-backfires-while-running
Please let us know what you find.
Cheers, Ken
Jun 18, 2018 at 4:49 AM
