Misfiring
2005 FORD MUSTANG
180,000 MILES • 4.0L • V6 • 2WD • MANUAL
KIMBERLY HANSEN
Every time I drive the car it sputters in 1st, 2nd, and 3rd gear. When I put it on the computer it said to change my EGR valve and so I did and it still does the same thing. It seems like it misfires. I changed the spark plug wires but it didn't fix it. What else could it be?
Aug 26, 2021 at 4:37 PM
MASTER ASE TECH
  • 82 POSTS
Hi, I'm Dan.
Misfires can be tracked down by eliminating things one at a time. Could be spark, fuel, vale related, or compression. Please see the attached articles to see if you can eliminate a couple things. I always try the easy things like spark plugs and such first.
In addition to this being a misfire, it could just be a fuel shortage causing a rough running condition. So not only do we need to check the spark plugs but we need to check the fuel pressure as well.
Here is a guide that will help with this.
Lastly can you remove the plugs and take a look at them to see if they are worn or showing signs of an issue. I am attaching a chart below that will show what they look like and the possible cause.
Please take a look at them and let us know which one they look closest too. Or just get a couple pictures of the plugs and we will be able to figure out next steps.
Thanks
Aug 27, 2021 at 3:43 AM
