Misfires and codes P0300 and P1684
2001 CHRYSLER PT CRUISER
230,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
SHERI WHEATON
We had bought the car listed above from a private party knowing that it needed the timing belt replaced which we did. But the moment it was started up it runs rough, and constantly misfires. It threw a P0300 code and a P1684. We replaced timing belt, replaced water pump, spark plugs, oil change, TCM replaced(old one was rusted through). Lived most of its life on a gravel road if that’s of any help. Cleaned ground chassis and reconnected it. Replaced battery. Cleaned ground wires coming from battery to the frame and checked all fuses in both fuse boxes. Car will randomly lose speed going up hill and will hear a loud popping from constant misfires. Door locks will randomly lock and unlock themselves. Seems to misfire between 2,000 and 3,000 RPM’s. No power locks at all. Key fob won’t work. And when opening rear hatch with key the tail lights will flicker. Idles really rough. Seems like there’s no acceleration and it has a rough time switching between gears, up shifting and down shifting. Headlights and high beams work. Until tonight the dash lights were so dim it could barely be read. And when trying to adjust the brightness level the dome light would come on right away no matter what we tried adjusting it to. Did this the whole time until now and decided to work correctly on its own. Think there might be a hole in the catalytic converter. That’s the next thing we’re going to check on. Any other thoughts or ideas? This is the only car we have at the moment so we need help in getting this fixed!!
Oct 24, 2019 at 1:05 PM
STEVE W.
  • 15,295 POSTS
Welcome to 2CarPros.
P1684 is a code saying that power was disconnected to the TCM. That would have been set while you were cleaning connections and changing the TCM.
P0300 is random multiple misfire. Which you seem to have.
Was the timing belt broken when you bought it or just worn and due for replacement?
I ask because if it was broken you very likely have at least a few bent valves which would show up as misfires. First test I would do would be a compression test to see what the cylinders are doing. https://www.2carpros.com/articles/how-to-test-engine-compression
You can get the tester at most parts stores as a loaner tool (you pay for the tool, and when you bring it back in the same condition they give you the money back.)
If you have say 140 psi in every cylinder it isn't likely to be bad valves.
A hole in the converter should set a code related to an O2 sensor.
Oct 24, 2019 at 6:38 PM
