Misfire, flashing check engine lights, ABS flashing lights
TUNDE MUYIWA ALUKO
  • 2002 TOYOTA HIGHLANDER
  • 2.4L
  • 4 CYL
  • 94,448 MILES
I replaced the engine in my base model SUV. The dash board shows flashing check engine and flashing ABS lights, and the error codes are P0300, P0301, P0141, P0161. I have changed coils, plugs, OCV, tested the sensor behind the wheel caliper. Problem: the car is sluggish, it takes two cranks to start, when it moves in some gears it accelerates very well but once there is a gear change it drags for a bit until the it kicks down to a lower gear. Which I have to rev very high before the next gear takes over. Help!
Thursday, April 6th, 2017 AT 7:25 AM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 54,348 POSTS
This sounds like a ground is loose, or has been left off after installing the engine. Please recheck all engine grounds and get back to us.
Best, Ken
Saturday, April 8th, 2017 AT 11:56 AM
